Hey you guys… still chasing my low oil pressure here and just bought some real Toyota oil filters, since some folks swear that other brand filters can cause low oil pressure... Call me skeptical on that; so I was also going to replace the oil cooler pressure relief spring and valve, and the oil pump pressure relief spring and valve.
So I put one of the new filters on today on and drained the out of the old one to see what I could see. It of course drains out from the outside of the filter can not the inside (threaded fitting). After letting it settle a while I slowly tipped the bowl and see lots of fine aluminum in it… hopefully aluminum that was caught by the filter and removed from the circulating oil. I am presuming it’s aluminum since it’s does not respond in the slightest to a strong magnet. So where’s all that aluminum coming from? Certainly not the block… See pic.
I was going to change the oil back to the good synthetic stuff, but might just go with less expensive stuff here first and see if it’s still happening. This is relatively fresh oil with 6 months and 1800 miles on it.
What do y’all think?
