So I met with the guys at Alternative Automotive today. Nice looking clean shop. This is the same shop and guys that rebuilt Frank’s engine not long ago. Bottom line is everyone is in agreement that the bottom end of the engine is caput… Just a matter of how badly.That's a bummer.
Yep, he (Steve?) mentioned that, but also said hey if your head was machined, rebuilt and tested by the Paradise VW machine shop in San Marcos it's probably good to go as those guys do great work. So, that was comforting. So he felt that not having to mess with the head was probably something that 'might' keep the job closer to $6K... Fingers and toes crossed on that...Also need to be ready for the shop to find other issues or near issues when in there. I ended up having a cracked head which was replaced with one of the few factory units left out there. I doubt you'll have surprises like that but sometimes the while you are in there stuff adds up.
Frank
Thanks for the tip on the transmission throttle cable Frank! Quite easy to get to and adjust, a good write up on it here... 80-series Throttle Adjustment - Land Cruiser Tech from IH8MUD.com - https://www.ih8mud.com/tech/80throttle.phpFor the time and money, and the distance we travel from civilization, I'd go with reliability and peace of mind. If you go through a shop you will also have a warranty you can lean on if you need to do so. I looked it as I could fix this land cruiser or buy a new one... clearly as much as paying someone to do a rebuild is, it is a lot cheaper than a new LC.
As to the transmission, does your truck run well enough to try adjusting the pressure cable? Maybe your year did away with it? If not, it's that lower cable that goes from the throttlebody to the transmission. The more pedal, the more pressure. When mine snapped in Moab my trans was a hot mess slipping, flaring, etc... so try adjusting the slack out of it. If the problem goes away, that was it.
Frank
Years later and I’m still bitterNowadays the CA smog rules are so strict, I haven't heard of anyone being successful in registering anything non original, especially diesel swaps. Factor having to register it out of state into your decision of doing any kind of swap. Alika from the club has a story where he paid the fees, got plates at a local DMV for his 70, only to get a letter from Sacramento saying that they can't honor it, and refused to refund him his fees. I was lucky to sneak in before regs changed and get mine CA registered, I still worry they will come and revoke it.
