From my vacuum shift conversion project. The pneumatic valve has worked flawlessly, and I now also have the option of 2WD low range as well thanks to eliminating the electrical solenoids. I tried hard to make it look as factory as possible, right down to doing up a 2WD version of Toyota's 4WD badge in Adobe Illustrator to be laser etched onto the label material (had to lay a special material over the plastic parts, since ABS itself can't be laser etched).
You can see that it's currently shifted into 4WD because I wanted to show how well the light shows up in daylight. Not well. I plan to replace it with an LED when I get around to ordering a batch from LEDtronics.
I'm also working on a writeup as I get the time to do it, but I still need to get a few more pics too. It's on its way though.
