Sliding rear side window removal...
woody
Staff member
Admin
Hurricane UT
searched, no dice....
is it possible to remove the sliding glass panes without taking the whole silly thing apart?
Tweaked with it a bit over lunch, couldn't get it to budge....figgered it could be pushed up/down enuf to pop free....
I don't think so newbie. :D
Was discussed a little while back in another thread I'll see if I can find it, dat search function is tricky. :D
You can remove it with a large, unsecured steel tookbox sitting on top of a wooden trail box. Make a hard left turn coming off the road to Goose Lake headed into Red River, NM and she'll pop right out onto the pavement. Crash.
You gotta take it apart. :)
Found the thread where the weatherstripping group buy was and it is discussed LX vs LC and if memory serves you have to remove the frame on the LC too but I could be wrong.
https://forum.ih8mud.com/showthread.php?t=25553&page=2&pp=50
Sorry Woodnick best I can do for you at the moment without my FSM.
I have yet to replace the gap in my weatherstrip even though I have the piece sitting there waiting for me to do it. HTH
nuts....so much for this project occurring on the kitchen counter....guess it'll have to happen in the heated garage instead....
tkx
happen to have my 94 FSM with me
Quarter Window Glass Removal
1. Remove floor mat support plate (remove 5 screws and the plate)
2. Remove Quarter Trim
a. insert a screw driver between the retainers and quarter trim to pry it loose
HINT : tape the screwdriver tip before use
b. remove the quarter trim
3. Remove rear pillar garnish
a. insert a screwdriver between the retainers and the 1/4 trim to pry it loose
4. Remove rear seat side garnishes and scuff plate
a. insert a screwdriver between the retainers and the body to pry it loose
HINT : tape the screw driver tip before use
b. pull out the side garnish
5. Remove the vent louver and 1/4 belt moulding
a. remove the nut from the vent louver
b. insert a screw driver between the retainers and body to prit it loose
c. pull out vent louver
d. pull out the clips from the edge of the panel, and remove the moulding
6 . Remove the 1/4 window glass
if reusing the weatherstrip:
a. using a screw driver loosen the weatherstrip from the body
NOTICE: be careful not to damage the body
b. pry the lip of the weatherstrip outward from the interior part of the body flange
c. pull the glass outwards and remove it with the weatherstrip.
if using new weatherstrip:
a. from outside of the vehicle, cut off the weathestrip w/ a knife
NOTICE: do not damage the body and the glass
b. push the glass outwards and remove the glass
c. remove the remaining weatherstrip.
1/4 window glass disassembly
1. remove the center weatherstrip (remove the screw and the weatherstrip)
2. remove the 1/4 window glass
pull up the sash and remove the 2 glasses
3. remove 1/4 window glass run from sash
4. remove 1/4 window weatherstip from sash
Quarter Window Glass Assembly
1. install 1/4 window weatherstrip on sash , see pic, sorry
NOTICE: if weatherstrip is hardened, it may develop leaks, use a new one if possible
2. Install 1/4 window galss run, as shown
3. install 1/4 window glass
pull up on the sash and install the 2 glasses
4 install center weatherstrip
install weatherstrip w/the screw
woah....thanks Nova....WAY more effort that I'm needing for this project....believe I'll plan to get away with removing the latch clips and dealing with it while installed...
Tkx!
no problem woody.. figure i brought it to work to read up on some stuff and had it handy..
4 words Woody ...
Window punch ....... crazy glue
:flipoff2:
Just curious.. what are you doing that you need or want to take out the slider windows?
figgered doing this on the kitchen counter would be easier.....but, once the latch was removed, it wasn't that tuff with the window on the truck
That is a sweet decal, any plans to make it public?
Or, as Ron White would say.... pubLIC?
Uz byatch why don't I have one of those to pimp my 80? :crybaby:
damn things are $30 ea...uugh...it's actually a "full window" sticker, done with very small holes so from the outside it looks great, and from the inside you can barely see it....
I pulled the latch, left the window 1/2 slid open, and with one of their funky "squeegies" and a lot of patience, got lucky and got 'em centered/installed right the first time.
The sticker shop was pretty sure i'd screw it up, and are planning to make me another on monday to fix my first attempt....lol....but my mad stickah skills prevailed....
Trim 'er out with a razor, and it's done....took about 20 mins each to do....
NO plans to make these a sale item, they really are too much of a PITA and expense to install, but I AM planning to do white outline stickers of some of the rig images....
