Slee wiring harness question (1 Viewer)
NC
Disclaimer: I am not electrically inclined.
Having said that, I can't figure out how to hook up the 12V power wire(s) from the slee harness. It's obviously not long enough to be ran straight to the battery. It has ring terminals on the end of the power wires, where do I connect these? I know it should be pretty straight forward. What am I missing? I am also hooking up the aux. lighting harness, same problem with that. Everything else was plug and play.
Yes, I did a search but evidently I am the only idiot with this problem.
Flame suit on,
Brad
EDIT: After sitting down with a cold :beer: it dawned on me that FZJ-80's have the battery located on the drivers side. That explains everything. I will call Christo tomorrow.
Didn't the harness come with installation instructions? I'm no electrical genius myself, but I was able to follow the steps outlined.
Pretty straight-forward, as I recall.
I don't know anything about the Slee harness. However, I notice you have a 1991 where the battery is on the other side of the engine compartment. Maybe the harness is made for the battery to be on the driver's side. It's a guess, but I suspect the answer.
