Slee wiring harness question
Discussion in '80-Series Tech' started by lowtops, Jun 30, 2005.
  1. lowtops
    lowtops
    553
    Media:
    1
    Albums:
    1
    274
    Feb 24, 2005
    NC
    Disclaimer: I am not electrically inclined.
    Having said that, I can't figure out how to hook up the 12V power wire(s) from the slee harness. It's obviously not long enough to be ran straight to the battery. It has ring terminals on the end of the power wires, where do I connect these? I know it should be pretty straight forward. What am I missing? I am also hooking up the aux. lighting harness, same problem with that. Everything else was plug and play.
    Yes, I did a search but evidently I am the only idiot with this problem.
    Flame suit on,
    Brad
    EDIT: After sitting down with a cold :beer: it dawned on me that FZJ-80's have the battery located on the drivers side. That explains everything. I will call Christo tomorrow.
  2. NorCalDoug
    NorCalDoug problems solved daily...
    6,294
    120
    Oct 27, 2003
    uhhhh...duh...Northern CA
    Didn't the harness come with installation instructions? I'm no electrical genius myself, but I was able to follow the steps outlined.
    Pretty straight-forward, as I recall.
  3. Cruiserdrew
    Cruiserdrew On the way there SILVER Star
    15,586
    4,636
    Mar 15, 2003
    Sacramento, CA
    I don't know anything about the Slee harness. However, I notice you have a 1991 where the battery is on the other side of the engine compartment. Maybe the harness is made for the battery to be on the driver's side. It's a guess, but I suspect the answer.
