Slee LX Slider Notes (1 Viewer)
TeCKis300
GOLD Star
San Diego
Since I'm at it, might as well capture some notes. Will develop this thread more as I figure out more things
First impressions - Packaging
Shipped as palatized freight in prodigious box. This thing is packaged to the nines to preserve the fine powercoat finish. Suitably impressed.
Weight
- LX factory steps cut. OEM AHC tube armor removed. Total weight removed 23lbs / side
- Slee slider weight including all bracketing and bolts - 54 lbs / side
Weight gain - 31 lbs / side, or 62 lbs net gain for slider armor. Weight is much better than I had hoped and a primary factor in my decision for having sliders at all.
Design
Quite impressed with the overall production quality and fitment of the Slee sliders. Well engineered and top notch. Evident in things like the bracketing design and consideration for each slider leg (4 total). Particularly how a torsional moment load path is engineered to channel through the vehicle frame where it has cross members. With the stiffest slider leg bracing through the frames strongest point at the transmission cross member, rather than less torsionally reinforced parts of the frame. This goes above and beyond most slider designs I've looked at. Kudos!
The reality is that everything bends with force no matter how stout, and this design manages potential forces in a hit with consideration to the overall system. An overly beefy slider doesn't mean more strength necessary. It just transmits forces to the next weakest link. There's a real chance with some designs out there that the frame becomes the weak link and I'd rather a slider bend before the frame frankly. Also, some flex is not a bad thing. Things that flex can survive to live another day. Overly stiff designs, break. I'd rather a slider deflect somewhat to absorb forces and bounce back to position and I think these Slee's are well designed in this regard.
Where the major legs are located along the frame. Larger supports have tie-ins with the cross-members.
These sliders seemed pricey to begin with but the value is there IMO.
More pics of the sliders please from different angles!
I think this has been pretty well discussed so apologize if I am beating a dead horse... do they shield the AHC at all? I know you mentioned you need to remove the AHC tubular armor.
Thanks in advance.
Thanks in advance.
It's a supplemental kit as @brasskey points out. It's a bit heavy-handed of a solution (albeit excellent protection) for me as I really want to keep weight down. I will likely add a minimal aluminum 1/4"x2" rail as minor protection. With as much lift and clearance as I have now, with the type of wheeling I do, the chance of contact is minimal.
Here's what the stock protection looks like. Mounted at no less than 5x points to the frame rail.
It's a supplemental kit as @brasskey points out. It's a bit heavy-handed of a solution for me as I really want to keep weight down. I will likely add a minimal aluminum 1/4"x2" rail as minor protection. With as much lift and clearance as I have now, with the type of wheeling I do, the chance of contact is minimal.
How much weight is the SLEE AHC protection?
EDIT: found it on SLEE site...38 lbs.
Slee lists them as 33 lbs.
It's helpful to see all these pictures, even though the LC install is very slightly different than the LX. My sliders are supposed to arrive tomorrow. I hope they haven't been damaged, though, since I see this on the tracking history:
An incident has occurred which may result in a service delay
Added packing info to the first post. I think you'll be fine as the packaging is robust - may be to protect other shipping items from the sliders! Hoping the incident is more to the carrier than the package.
Does the slider sit LOWER than those AHC bulbs ??
Both frame rails and slider are lower.
I saw Teck answer - but yea frame rails and undersided mounting hardware continue to be the lowest point of the truck. A couple of weeks ago I dragged my passenger side across an obstacle and sliders totally saved me. The truck rested on the mounting feet where they attach the the frame.
Do you have the extra AHC bulb protection Plates? Saw your video...how did the sliders come out? Any slider damage?
I don't have the plates, my sliders are the "old" design but could be retrofitted with the plates. The plates would protect against something intruding the globes — like a branch or stump — but otherwise they are already *well* protected from slides or impacts along the rocker.
Sliders were totally fine, just some scrapes in the powder coat that can be easily touched up.
If you look at Slee's page again, you'll note there's two weights. I believe 38 lbs is the shipping weight, 33 lbs is item weight.
Weight
Design
Quite impressed with the overall production quality and fitment of the Slee sliders. Well engineered and top notch. Evident in things like the bracketing design and consideration for each slider leg (4 total). Particularly how a torsional moment load path is engineered to channel through the vehicle frame where it has cross members. With the stiffest slider leg bracing through the frames strongest point at the transmission cross member, rather than less torsionally reinforced parts of the frame. This goes above and beyond most slider designs I've looked at. Everything bends with force no matter how stout, and this design manages potential forces in a hit with consideration to the overall system. Kudos!
Where the major legs are located along the frame. Larger supports with tie-ins into the cross-members.
These sliders seemed pricey to begin with but the value is all there IMO.
Thank for all the kind words! The gang here appreciates the feedback. Thanks for your support, and glad you like them so far.
Cheers!
Will be interesting to see a install thread of these sliders on a LC for comparison.
Just got done with the single rivnut for my install. I didn't bother with the Slee rivnut install tools as the LX install only has a single rivnut to set. I'd highly recommend them for the LC as there's several rivnuts to install.
In trade, the LC rocker panel won't need any attention. This took some detail work to cut to my satisfaction.
Rivnut notes
- 17/32 drill bit, this is an oddball size that I'd be surprised if anyone has in their garage. I winged it and drilled to 1/2" with a stepped bit. Then use a drill sandpaper cartridge roll and hogged it out the extra mm. Really want to make sure the rivnut installs tight.
- Rivnut setter, DIY'd with the many youtube tutorials out there
