Skid plate part numbers
Str8Razor
Chesapeake, Va.
I need to replace the front skid plates where they were not replaced by someone doing an oil change. I can’t figure out the part numbers after having looked at a couple of parts websites, I will also need the bolts… I found a picture of what i am looking for in another thread but could not find the part numbers, will need the bolts/ hardware to re install it as well….
Thanks for any help!!!!
Thanks for any help!!!!View attachment 2771117
Might want to ask if anyone here has their left over stock skids.
Also had that issue. Here is what I ordered.
Shield - pan that covers oil filter
Protector - transmission pan cover
Rear sheild - oil drain cover
Once you pull up one shield they all come up. Then you can pick what you need. Pretty sure the bolts came up also. Hope this helps
Thanks a lot man, got the parts ordered this morning hope to have them later this week, good looking out!!
Mine was also missing when I purchased it. Full service from dealer every 5k miles. Lazy techs is my guess. Not to mention owners that never bothered to look afterwards? Should they really have too?
No doubt that's why we here bro
Did the oil change today, still waiting on skid plate parts but I was unable to get the filter drain plug to seperate from the filter housing, it’s over torqued, It spun the whole filter housing out when I tried to loosen in…. Hot oil every where… going to order another housing and drain plug as I can’t afford to break the housing and have the truck down… I even put it in a vise and still couldn’t get it to break free… will order the new stuff and have it ready for the next oil change…
Look into the aluminum part from a venza. You’ll have to move your filter support tube over but that is easy. The drain plug goes to 9ft-lb and the cover to 18.
