Well i am not sure what to tell you, for my rig it is presenting a problem. Forgive me but am still not convinced that your design does not move the door inward the same amount of the movement you did to the hinge pin (.200 inches according to my measurements , which not slight in terms of door adjustments)
So please help me understand how you compensated for that.... if i hear you correct ....you moved X3 so the doors have clearance to come off,. IF nothing else changed then effectively you have moved the Hinge point centerline of the door as the centerline is the imaginary line running between both upper and lower hinges vertically thru the center of the pin. And since it was moved out, and assuming the inner hinge point remains fixed, the door will move "in" tighter to jam
But sounds like you must have had to move X2 dimension per my drawing on the matching inner hinge plate the same amount to compensate for correct spacing in that X direction ? IF you did then the door gap between inner jam and inner face of door remains the same allowing for the same gap for weatherstripping, but the effective CL of door still has moved out the same about. And that should be fine, i dont see why that would have any bad effects on the door.
but if X1 and X2 dimensions were not moved to compensate then no way the closed mounting position is exact in that closed position?...... giving the same position of the nut plate. The closing center-line would move out away from dash the same amount, and forcing the door tighter inward at the hinge point.
And even worse if X2 was moved inward to compensate for keeping the CL of the doors the same as OEM.
In other words, if the centerline of the door hinge pin was moved out. without any other changes in the inner hinge, then my point is valid. and will present a problem,... if the nut plate cant be forgiving enough and overcome the distance by moving far enough out.
But if others aren't having a problem then you must have considered this and made it right. If i had an OEM inner hinge plate, i could compare the assemblies and become an instant believer but i am going to have to take you word for it.
Looking for HELP here. I am using brand new OEM weatherstripping, Doors unaltered in the hinge area, only repairs were to the bottom of doors. . i am using brand new OEM weatherstripping, Doors unaltered in the hinge area, only repairs were to the bottom of doors. ?????? Why just ME? Trust me if there is another way or if i am missing something i am all ears. I dont want to have to take off all the inner hinges and slot that is a royal PITA . I see no solution but to Slot at this point , Do i just have a tighter than normal nut plate compared to others, ( that sounded kind of clinical
) HEHEHE .... my nut plate is not as forgiving? Maybe tolerance stack ups ? ANyone else have this issue?
