Anything that you would add that would need to be bent before the other vehicle contacts the door, etc
would theoretically absorb energy, so less to go into the occupants; however,
if the thing you add to the side then breaks, instead of bending, it can become a missle
that could then enter the passenger compartment, which could be a worse outcome.
Any side impact is a bad deal; as even if the passenger is not struck directly,
the lateral forces ie: on the neck could fracture the cervical spine(sideways whiplash) and tear internal organs from the acceleration forces. A small childs neck has more "play"(more flexible) so they are a bit less likely to get a fractured neck from a crash; depends on the scenario.
Having said this, it does depend on the mass of the object being stuck and the mass of
the object doing the striking; basic physics;
ie: if you are in a three ton LC and someone in a Dodge Neon strikes you, the Neon will lose;
just half the mass of the LC.
On the other hand, if you are T-boned by a Semi; then no amount of extra metal or airbags
are gonna make much of a difference. The semi driver gets a sore thumb and you get a toe tag.
I have driven LC's all over the world, and have seen what damage can be caused by roll-overs, etc,etc.
I have seen Mercedes G-Wagons ($120,000) fold up in a rollover, same with full size Land Rovers;
not so with the LC's; sure the doors and the roof get a bit bent, but you could drive away from
a complete rollover; I have seen it happen.
I can attest that if I had a choice to be in a LC or any other vehicle, with comparable safety features,
I would pick the LC hands down everytime. Side curtain airbags do work for the person sitting next to the door, just have to buy a newer LC for that level of protection.
To protect a child, I would buy the biggest baddest carseat on the market, read the instructions,
and install it properly; as you said, in the center rear seat.
