Thanks
Is this by any chance supposed to be disconnected?
It should be connected....
Obviously
Idle up when power steering is engaged. You probably see a slight increase in rpm at idle when turning the steering wheel.
Don't be so hard on yourself. No such thing as a stupid question. Glad I could answer part of it for you.There is nothing honorable in being an imbicile.
Turning the steering increases load on the engine a bit, since the power steering pump is powered by the serpentine belt. So there's a system in place to increase the idle slightly, so the load of steering (while idling) doesn't lower the rpms enough to stall the engine.Not quite sure I understand. Can you elaborate?
