BigMike
Supporting Vendor
Short Throw Shift Kit Install Guide for G- and R-series Transmissions
This guide will help you install our Short Throw Kit onto a G52/G54/G58/R150F/R151F transmission. Please carefully read and familiarize yourself with the following procedures before installation.
If you have any questions, visit http://www.MarlinCrawler.com or call us at (559) 25-CRAWL
This kit is comprised of the following components:
Prelude: Your transmission will be exposed during this installation process. Be extra careful to clean your interior or workspace to minimize the risk of any debris or foreign object from falling into your transmission. Also, note the direction of your shift handle as our new handle may be installed in two different orientations and only one will match how your handle is now.
To begin, engage your emergency brake and shift your truck into neutral. (Shifting into netural will make the reassembly process much easier so don't skip this!) Remove your shift handle boot from your shifter base. Push down and rotate the shifter retainer counter-clockwise to unlock the shift handle as shown in the following image:
Next simply lift the shift handle up removing it from the base. Remove the four shift base bolts using a 12mm wrench or socket.
Using a brass drift, brass hammer, and/or flat head screwdriver, gently repeatedly tap on the stock shifter base until its seal is broken. You may also tap on the sides of the shift pivot pins.
- (1) Modified Short Throw Handle with Marlin Crawler Heavy Duty Shift Socket and Toyota Boot
- (1) Short Throw Shift Base Assembly
- (1) HD Shifter Seat
- (4) 20mm X 8mm X 1.25mm Base Bolts
- (4) 8mm Lock Washers
