All,
While in the Chik-Fil-A drive-through yesterday, I lost all coolant. A quick look at the steamy engine compartment revealed a disconnected hose which I, probably erroneously, figured was the source of the leak (see photos). Without the time or expertise to inspect further, I returned to the office and arranged for a tow. A new-to-me, but mud-reccomended, shop advised that the radiator's lower tank was the source of the leak, but couldn't explain if/how the tank leak was related to the disconnected hose. Records show that the radiator was replaced by the p/o Nov. 2015 -- 30K miles ago.
The shop, who also performed a state inspection, indicated that the steering rack was leaking severely and that the rig required a replacement rack, pinion and bushings (also suggested new outer tie-rods). It appears that the p/o's shop also replaced a "faulty leaking rack & pinion" with a re-manfd "complete rack assembly" in Jul. 2015 -- 35k miles ago.
Not having worked with this shop, I decided to have her towed home where I plan to inspect over the weekend. Assuming these parts actually need replacement, should I just chalk up the limited life of the steering rack and radiator to low-quality parts/install by the p/o -- or are there underlying issues I need to be aware of? FWIW, it doesn't appear that I, or the p/o, replaced the coolant since the radiator was installed. Same for the steering fluid since the rack install.
I'm not nearly as technically savvy as the collective group, so I appreciate any guidance on these issues. If replacement is warranted I plan to buy, and have this shop install (unless I'm being swindled), a Denso radiator and steering components I'm yet to research. I did consult the "cooling system" section of the manual, but my feeble brain couldn't connect the dots (if any) b/w the disconnected hose and radiator.
p.s. I secured the nuggets and waffle fries before ubering back to the office.
Thanks,
Thanks,
