The leaf springs 'feel' as though they're shifiting a lot !
Can see leaves are askew; can see where they 'bang' the 'brackets' that are about halfway 'tween axle and frame mounts.
Put 'em on about 3 yr ago: 2 weeks after install, checked (applied a tad more) torque of nuts.
Thinking:
- frame on jackstands so axle hangs
- 'just' loosen nuts (1/8 turn, break rust tourque)
. . .maybe hammer leaves into a stacked alignment ?
- retorque to 100ish ft-lbs (FSM value range)
or should I just apply torque wrench as it sits on road ?
This shifting is bothersome as all get out: noisey and can feel it when leaves hit the 'bracket'
Oh, I know it's not knuckle bearings . . .and spring bushings are 3 yr old too....
Thanks,
Pete
Thinking:
Thanks,
Pete
