Shaving a late 2F head
I took 1mm off my 3f head and run 91 octane with no problems noted.
About the MAF pistons. They are advertised as a 9:1CR at 1mm overbore.
1mm overbore on a stock engine= 8.42:1
1mm overbore, flattop piston, 1mm mill= 8.9:1
9 is the max I want to see in a Cruiser engine. Anymore will require hi-test gas, which is not always readily available in the middle of nowhere. I hafta run 91 octane in my engine that is accidentally at 9.0 (1.5 overbore, .75 mill, flatface valves). Fillups cost 10% more, for a 5% gain in power/efficiency. Not a good deal. I threw the engine together without crunching numbers and will pay extra for the next 200K miles.
Be careful with high compression pistons. Do the math before cutting any metal.
Running at mainly sea level to 1000 feet with max elevations usually under 4000 I have had no problems running up to about 9.3:1 on regular fuel. If I do choose to run premium the cost difference is minimal here. under 5% Before I worry about that difference, I will be lookng at a lot of the inherent economy sacrifices that a Cruiser requires anyway.
Mark...
Mark...
What camshafts are you guys running with these compression ratios?
With my 2FE I run a Delta KC859 grind (262* I believe) and 8.8:1 static compression (7.3:1 dynamic compression) and have had it rattle on one tank of bad regular gas in Canada plus user error in Montana where I forgot that regular gas=moose piss.
Yep, cam does make a difference. More so at lower rpm than higher. I'm running the same KC859 cam in my 2 and 3 F engines.
Mark...
I always run the blueprint MC803 melling cam, which is very tight, making the engine rattle at 9:1
Good excuse for me to send a core to Delta to be reground and lose some compression...
