Here's some shots of a Scout pittman arm that has been modified. It has been shortened to 7 inches (appropriate to the Cruiser knuckle arms). It has had the tierod end flipped to put the draglink on top of the arm instead of underneath. It has also been configured with a dogleg to match the angle of the double knuckle arm so that the steering is centered and has the same number of turns left and right.
This shot shows the pittman tucking under the frame. You can see it is close. There is more room between the arm and the spring than is looks like from this angle. And the ubolt plate is further back in relation to the steering box than it looks like in this shot too.
From the other side you can see just how close it really is. The zerk clears the frame by 1/4-1/8 inch. All it needs and no more.
This angle shows the dogleg (not needed on a rig which still attaches the draglink to the tierod). It also shows how beefy the scout arm is (it doesn't immediately looks so in it's stock length, but when you shorten it, it's a bit more noticable).
This is just a quick twist to look things over with the new springs. It's not completely flexed out, but as you can see in the last shot...
I found the limiting factor (for the moment anyway). The driverside tire is meeting the shock at this point. The next step is to move the mounting points at the top and bottom of the shock(s) inboard some. This should solve this clearance problem. Then we'll see what binds next. Eventually it will be the spring/pittman arm. But there's a lot more room left before that happens, once the shock is out of the way a bit.
Mark...
