Replaced my old 2H with a 1HZ-T and selling off various bits. I also have the engine block with lots still on it, but I can't use a wrench until rotator cuff surgery heals up (Feb 21?). Here's what's left from my initial sale. I can only use 10 pictures in a post, so if you want to see items that do not have pics, let me know and I can send them.
Prices do no include the ride.
SOLDEDIC motor $100
Clutch. Looks good with lots of life left. Heavy and around $100 to send. $90
Upper and lower Radiator hoses. The lower one has a block heater installed which was great at 8600' in Colorado and useless in SC. $40 for both
SOLDManifold heat shields. 3 of them. $70
Fuel relays 28590-56090. 2 of them. was having trouble with my EDIC motor cycling randomly, so I bought a used one for $600 and it didn't fix the problem. Removed the gp system in the new setup. Not sure of their functionality, so $50 for both.
SOLDTach sensor. Missing connector $40
SOLD entire blockItem still on the engine block include IP, oil cooler, oil pan, fuel pipes, autotimer, Cyl head cover, cylinder head (not sure of condition), oil filter bracket, fuel filter assy and pump (newish), intake/exhaust manifolds.
Air filter top and down pipe. $80
Fan $50 and Clutch $140 or $160 for both
Glow plug system. Includes 6 glow plugs (new in 2016), relay controller, resistor $200
PS system. Includes pump, reservoir, lines, hoses, brackets. In a large box because of the hard lines. $500
Heater Valve. This is for the RHD trucks and unobtainium. $50
Alternator assembly. Includes vacuum pump, oil hoses, pulleys, bracket and bolts, and voltage compensator. $600
SOLD
SOLD
SOLD
SOLD entire block
