Scangauge 3 A pillar mount (1 Viewer)
Utah
Looking for some feedback. I got tired of the wobbly windshield suction mount that came with my scangauge 3 so I designed up a new case that has an integrated ram mount and cuts .6" off the overall width. This is a direct swap for the sg3 housing, it takes 4 screws on the back to separate and swap the screen over. Same 4 screws are used to secure the new mount. Will be sold by itself and as a complete kit with a modified dual swivel ram extension and the A pillar ram mount.
This setup doesn't block any personal or defroster vents and puts the scangauge further into the corner than any other hard mount option. Technically I've found a dual swivel ram mount thats 6" long (compared to this 4") to tuck it even closer to the windshield if needed.
I could modify the design to be mounted on passenger side of LX dash where my phone charger option currently sits. Is there anywhere else people would want a mount designed?
How much$
I want to put it off the a pillar like yours.
Does it use one of the grab handle bolts?
How much$
I have an official sale listing in the small business section but here's the link as well.
New socket cap bolt included with the complete kit, but yes it does replace the lower grab handle bolt.
I don't see the 6 inch option
Il be getting that added today once its delivered and I grab installed product photos. The 6" extension is a couple dollars more but I'll update when available.
Will I be able to touch the scanguage with the 6 inch? Here's what I cobbled together for the past year which isn't bad but I like your option better. Can you update me with Pictures so I can see the difference between the 4 and 6 inch. Either way ill be buying one or the other. Thanks
What are you monitoring with the Scan Gauge? Trans temps for towing? What other live data is valuable to see?
You can monitor pretty much anything that's able to be read by OBD2. Ive got trans, tcase, coolant temps, along with some MPG info, adjusted speedometer due to tire size, it can also read codes and diagnostics. Their sight gives much more info than I can!
Yours reads transfer case temp? What year is your 200? Where did you find the setting for t case?
I misspoke typing too fast. Temp 1 is pan temp, Temp 2 is convertor temp, not transfer case.
Just wanted to say how impressed I am with my new scanguage case and ram mount. Uto8lx570 puts out a nice product. I decided to adjust mine so it's lower on the dash and not sticking up over it like it was as seen in my earlier pictures above.
