IH8WINTER....
Well it's been far too long and I've done far too little - I blame the cold and a non-heated shop. Today it warmed up above freezing and I managed to convince myself to just get a little bit done. With a little bit done, I'm a little bit closer to getting back to working on finishing my 40, which means I'm a little bit closer to starting the 45...... That's a long tunnel with a pinpoint of light at the end....
So, today I attacked the fuel filler. Of all the parts I've had to fix, this one has been the worst. If there was one part on the truck that I have had to make that I could buy, this would be it - but I don't think it's a part I can buy!
So, here is the nastyness. This part was previously damaged, and repaired, and damaged again by corrosion behind the bondo, so it's in incrediy rough shape.
After blasting, I actually used my air saw as a seam sealer/bondo remover - some of that stuff was stuck HARD!!! Worked great though, and I managed to get it cleaned up satisfactorily.
Next I cut away the rot - or what was left of it - in the lower forward corner. Again I made a strip, bent it in my bender and cut slits to bend a radius. (Too tight and not enough meat for the stretcher) I replaced the outer lip, on the forward lower, and lower forward edge (hope that makes sense!) I always left a piece of the original to tie to so that I had a reference point.
I also cut away the lip and the flat of the lower rear corner. Welded a new flat in (above pic, under my thumb) before replacing the lip. (Pic below) Next I removed the lip from the entire back edge, upper rear corner and half of the top. Looks a little wonky in the pic below.
Once those welds were all done, I trimmed the excess "lip" off. Now, keep in mind what I said earlier about this being a pain in the ass part to build. I fully understand why the previous "repair" used a filler, and though I did what I could to smooth the welds out, it's nearly impossible with the tooling that I have, to get this 100% metal (without spending an even more rediculous amount of time on it!) the shape is about 95% there - but it will need some filler! (I promise to use the good stuff!
Next I hit it with a coat of galvanizing paint to help protect the back side where paint won't reach it after assembly, and tacked it in place on the truck.(note the offset that I cut when I removed it for easy re-installation)
I marked out where the edges are, how far down the bottom is, and where the corners are so I can transfer that into the quarter panel to cut out.
Still have a bit of work on the bottom rear corner of the wheel well, and a major fix in the front before I can put the quarter panel on.
5 hours today, total now up to 95!!!
For those who are also trapped indoors on these cold winter nights, looking for some entertainment, I highly reccomend watching the X-overland series, cool stuff.
www.xoverland.com
Props to
@xoverland and @cruiseroutfit and everyone else involved in the production.
We just finished watching it, and - seems that the plans now are to sell our 5th wheel and load up the 70 when it's done! (Or whichever of the cruisers is available at the time). The eventual plan for the 45 was/is an overland rig. Have to love it when she says stuff like "probably better to spend a bit more money and buy the ARB, it looks like better quality."
So, now on the hunt for a RTT, and need to build a roof rack for the 70 that can hold the RTT and a Foxwing awning, a drawer "kitchen" for the back, and beef up the suspension!
Looks like this "saving" thread might just turn into a build thread by the time it's done!!
