Sandwish adapter
Just be careful.
I beleve Toyo Oil pressure sender uses 1/8 BST thread and most oil temp threads are 1/8 standard pipe thread.
I’d double check first, since that part is coming from China. Their return policy probably isn’t the best. I’d personally just get a tee from Jegs or Summit Racing if you want temp and pressure info from the oil system.
Bottom line, I would select what gauge system I want first (VDO , Autometer, etc) find out what sender thread sizes they use and then buy my tee adapter with appropriate size threads.
Maybe you don't want to hear this but I did as Dprio suggests: I bought a British Straight pipe Thread tee fitting and put the old Toyota sender on it in a better position. I also put a BST to NPT american pipe thread adapter (it's small) onto that for the soon-to-be mechanical gauge I have.
British Standard Pipe - Wikipedia
National pipe thread - Wikipedia
