Having been one of millions of folks to experience the blackout in Texas this week, I got a little experimental with my extra LC100. Basically, I used my 2003 for shuttling family (also without power) to my home and buying essentials, and the other as an electrical generator. I had a 1000W power inverter (12VDC to 120VAC) laying around that I fitted to my 2000LC's battery, which was sufficient to power the fan/fuel valve on my home's gas furnace, power my gas fired tankless water heater, and leave power to spare for a few lights and phone/laptop charging stations... and the very critical Swiss coffee machine. Made things fairly comfortable for the 20 or so hours until power returned.
To minimize fuel burn and reduce trips to the gas station (very difficult!!) was pull four of the fuel injector connectors - from cylinders 8, 3, 5, and 2. My thinking was that this would create the most balanced firing of cylinders (every other firing, see image below) and also lessen (halve?) fuel burn from the constant idle. My question is, would this actually halve fuel consumption?
Initially, the idle dropped 100-200 rpm, but after a bit the ECU figured things out and got the idle up to just under normal. I wonder if the ECU just doubled the fuel delivered to each of the four cylinders running, so to not burn any less than the normal 8 cylinders? It not being practical to compare running 4 cylinders with all 8 over the same time period, I really can't know, but I am curious if I can extend runtime this way, as I'm almost certain I'll do this again some day.
Note that I didn't run the full 20 hours. I don't know how long in total. I shut it off at night and other times when power wasn't absolutely necessary. Only burned 1/4-1/3 tank in total.
