running lights....
woody
Staff member
Admin
Hurricane UT
Now, this is strange....
Hazards - all work
turn signals - all work
brake lights - all work
REAR running lights - all work
FRONT running lights......nuthin...zip...zilch....
is there a separate fuse for the front circuit I couldn't find, or is there a separate connector for that circuit (underdash) that's loose/not connected?
Or, magically, did both front bulbs blow simultaneously??
(loaded for a trip, FSM at home on the counter, and like most noobies, I haven't even popped the fricken hood to see if the stupid blubs are blown or not....) :doh:
YOU LEFT THE FSM AT HOME ON THE COUNTER. :doh:
:censor: noobs.
Sorry mine's at home too. :D
Diggin up this thread because: don't have FSM or Driver's manual with me, I have a somewhat dumb question, and to let you know I searched.
My question: do the marker/running lights turn off when the headlights are on?
If so, how can I change this so they are always on?
Thanks
Sorry, I misled you. I want them on with the headlights.
They're on when the headlights are on -- yes.
They turn on when you turn the headlight stalk to the first position and stay on when the headlights are on.
You're talking about the lights on the front corner, correct?
Correct, except mine are now in the original turn signal location.
I'll have to look at this again. I only noticed it after the signal mod. Perhaps the 5w marker bulb is too weak to notice through the amber lense. Or more likely my observation skill have weakened.
My $ is on the bulbs. One went out, you didn't notice, the other went, out.
My 94 engine light went on and I checked all the electronics. The two marker lights were out BOTH AT THE SAME TIME. Replaced the bulbs reset the check engine light and all is well.
It has been 9 months since Woody asked...hopefully he got them fixed...
As for Rolliges, yes the marker lights should be on when the headlights are on.
Yep, they're running when I am. Poor observation during daylight while giddy with the running/turn signal switch-a-roo mod! Now about that head gasket....
How do I get to my two front marker lights to change them? The passenger side looks barried in there? Any help would be great.
Open the hood, remove the one and only screw on top, pull the entire assembly straight forward. It will pop out.
The directions are in your owner's manual.
