Brief History - '82 Land Cruiser purchased with '85-'87 Chevy 350 (dead motor), installed '92 Chevy 350. Water pump on old engine had a return line port on the top, new one doesn't cause the '90s chevy trucks had the return line at the top of the radiator.
Things I've tried:
- lower temp thermostat
- higher temp thermostat
- no thermostat
- by pass heater core (thinking it was clogged)
My concern is that my only place to hook up the return line on the current configuration is the side of the block (commonly used for block heater lines)
Does anyone else here think that I may be running a little hot (almost 220 degrees) due to the small size of this inlet 3/8" as opposed to the 3/4" inlet on the old water pump or '90s Chevy radiators?
See here:
Things I've tried:
- no thermostat
See here:
