Rubbermaid Actionpacker
I have used this box for a couple of years now and like it just fine. I cannot speak to the UV aspect it typically is not exposed for long periods of time. Fairly durable and for the price I think is a great container.
This weekend will be my first outing with the HD 20 gallon boxes I bought. They stack and strap very securely in the rear of the 80.
These boxes worked out well for me. The camping supply box was left out in the rain all night and everything stayed dry inside. I really like the hinged lid. Very stout but doesn't get brittle in cold temps. They stack really well.
These things are next on my list on a rearrangement of my trailer. Old cheap Home Depot type that opens in the middle leaks like mad. Left it out Saturday evening at SnT and it poured soaking all my cast iron ware that was in it. Dried it all out and it'll be fine, but need something better. Also need one to get all my kitchen gear out of the drawer in the truck and into an actionpacker type box in the trailer so I don't keep running to the truck for stuff!
Never ending!
A lot of nice options on this thread. Thanks for all the information.
I checked out most of the ones mentioned but ultimately went with a cheap alternative, and may change depending on how it works (or doesn't work) out.
The J. Terence Thompson Plastic 27 Gal. Snap Lid Tote Yellow/Black at Lowes for about $14.
  • Capacity: 27 gal. / 750 lbs.
  • Dimensions: 29 x 20.5 x 15
  • Stackable
No experience yet, but will have to see how long it lasts and holds up to UV, etc.
I use these and like them better than the rubbermaid containers I used to have. Especially for the price. They don't latch but the lids fit sufficiently snug that they won't blow away when sitting outdoors. I usually cargo strap them down when they are in the back of my truck and I can stack them two high and fit my chuck box too. I think the lids are rated for 300lbs., so they make a good step stool when you need to stand on something (rigging tarps, etc...)
I've had no problems with my large Action Packers. I store them out of the sun and rain. First one has all my camping stove, lantern, dishes, etc.. Second one carries firewood, axe, and shovel.
I've got 4 large action packers and one small one that have been great. The 4 fit nice in the trailer and keep things nice and dry. Got the last 3 at Walmart as much as I hate shopping there.
yes, I do have one and it looks like it is not rigid enough to sleep on top of. And as mentioned above, the shape is a bit odd although it might help to squeeze it next to the wheelwells.
Here is the one from Homedepot I mentioned:
20-Gallon Multi-Purpose Storage Container-43118 at The Home Depot
Note that I think it would be waterproof sitting in the rain given the overlapping top, but I don't think it would be if it were on your roof driving in the rain where the water can be blown in, since it does not have a gasket (although I'm looking at adding one). There is a bigger one too, but I think it's too big for my truck uses. The 20 gal one is not as tall as the 24 Action packer one either, so it's easier to stack in the truck, easier to sleep on, and less protruding if on the roof rack. Plus it has a big hinge which would help with retention in case of a rollover. That thing is perfectly rigid.
Picked up two of these last night.
The 20 gal is perfect size for camping. Small enough I could move it by myself if I had to, large enough to store a decent amount of gear.
The 40 gal is huge. That'd be a great one for sitting in your trailer...and never getting removed.
just picked up a couple of these for $14 , as some others also have.
so far i like them. the concave upper portion is really useful for holding small items.
there are many slits in the sides of the lid/container that allow a strap to be threaded through so you can secure them down to the vehicle and/or to each other. they stack nicely and keep normal rain out so far. it wouldn't be too hard to add a rubber seal if one were so inclined.
the lids do not lock, but ratchet straps and bungee cords are cheap and plentiful enough
take a look at them next time you're wandering home depot/ lowes.
I noticed that three shoebox sized containers with lids fit side by side in the bottom.
i'll likely be buying more of them.
Run a thin(real thin so the lid will still lock down) bead of silicone sealant around the inside of lid to help with sealing.
old rubbermaid box
I have an old Rubbermaid carrying box that I've used for 20 years. It's about 31"L x 13" H x 16" D outside.
This particular box is a very useful size for what I carry, is stackable, the lid seals securely, and it has held up very well over dozens of trips. If anyone knows where I can get a couple more let me know!
Those are pretty good, but don't let them stay in the sun for long periods. Store them inside when not in use. They do hold up reasonably well to sunlight, but it accelerates their demise. I have 4 on the farm for collections of parts and tools for fencing work and other uses, but eventually the latches die. They really don't like extreme cold. I've replaced the latches on one with hasps and linch pins. The mod made it easier to open as I can grab on the hasps to lift the lid.
Thanks for the tip on those boxes. Are they strong enough for us heavy guys to sit on?
They are stamped with a warning not to sit/stand on it, but I think they would be plenty strong enough.
Google Dewalt toughsystem case. They have a sweet new line of storage boxes. Went to the tool shop to day and was very impressed with the quality. The large and XL sizes are perfect.
I use a series of action packer imitations. Picked them up at Walmart for about $18 a piece, and are about the same size as the rubbermaid versions. They're hinged on one side, and one latch, instead of two latches. They also make a larger version that has legs, but I hadn't picked one up yet.
With the family camping with me, I keep most of the stuff in them year round, so I know what's in them, and they stay packed up in their own spot.
I just lined the interior lip where the lid and the bin meet, with some weatherstripping. Keeps the water out during use, and bugs out while being stored.
Here's a link:
http://www.walmart.com/search/searc...nd&_ta=1&search_query=styleworks&_tt=stylewor
I love my Action packers and have looked a lot for similar products. Saw this today at a nearby Wal-mart Supercenter. It was pretty heavy (compared to the Action packer) but it was nice and sturdy. With the legs down it was stable and just the right height for cooking or food prep. The wheels were a big bonus, too. Cost was a little high, though. $89 US.
Please forgive the crappy iPhone photos. The lid is removable, if you undo the retaining straps.
gotta have one or two that you can keep the lid closed with the latching mechanism. I like some of the other type "storage bins" but the ability to keep the top closed is a good feature.
Costco is carrying the Action Packer for about $25 right now...at least in the local SoCal stores nere me.
