Rubber Donuts - Replacing Accumulators (1 Viewer)
DownTheRoad
GOLD Star
Santa Fe, NM
First, I have no idea what I'm doing or talking about when it comes to suspension of the LX570. As an engineer, I like to take apart things to break them. 🥰
So, I have the AHC Fluid on order (5L ar about $30 per L including shipping and taxes). I also am about to pull the trigger on the Accumulators. Stateside are $750, from Japan are $400-560 plus duties. Anyone purchased accumulators from a Japan seller and paid duties recently, about how much extra?
The fluid flush, and accumulator replacement looks pretty basic thanks to the wealth of forum members giving it a go before my attempt.
Anyways, while I was under the truck effing around I noticed some rubber Donuts (bump stops?) along the suspension system that are cracked. Is it a fairly easy, driveway job to replace them? This got me to wondering what other components should I be replacing as preventative maintenance and to get the suspension tighter. I am at 117k miles for a 2010 LX570, on 18" wheels.
The advice I've received is start with globes/fluid.
It is a driveway job, here is one video on the topic
Rear suspension rebuild/refresh (no video)
The more you dig, the more you will find. Good luck.
Show us a picture of the cracked bump stops.
You're probably ok anyway. The LX is pretty good at keeping the suspension from harshly bottoming out.
48817-60020. Need two per side, or total of 4.
@TeCKis300 Thank you for the part number and exploded view.
