I'm in the process of doing the front.. seems like the tundra outer tie rod is not long enough ..does the inner tie rod need to be swapped out?
I've only got the one side apart so only the one side is pigeon-toed inso both sides are pigeon toed in?
Yes correct.. same here I was thinking the tie rod outer must be too short but it's exactly an inch and a half longer than the Land Cruiser outer tie rod. When I thread it to where it should be with the wheel pointing straight there's hardly any thread left on the inner tie rod..I'm assuming you threaded the Tundra outer tie rod ends to where the LC tie rods were originally?
I did this when I did the swap and mine was pigeon toed too.
I remember thinking the tie rod end should be a little longer, but I turned them out until the tires were straight.
When I get home, I'll get a picture of where my tie rod ends ended up.
Also, what brand are your Tundra parts? Lower arms, upper arms, axles, and tie rod ends?
