When I purchased my 80 a few years ago the seller thought the hg was blown so I got a really good deal on it. I drove it about 100 miles home. Didn't have a single issue. This was all on the highway though. The next day I was driving around town and it started to overheat. Got it back home and you could actually see bubbles in the reservoir. One about every second. There was no milshake, or moisture out of the tailpipe. I drained the system and refilled making sure to get all of the air out of the system and replaced the radiator cap. Same symptoms, overheating and bubbles in the reservoir. I would definitely not put any kind of stop leak product in the system. You'll never get all of that crap out. Fix it the right way.
100% doing it properly and the right way - 10 year build and whenever I replace anything its always been OEM or if better aftermarket - also keep an ongoing record.....most of the work done is captured below and pictures in my build thread .............mostly I do the work myself but some things I cant (like engine rebuilds).....never planning to sell this thing....contemplated it once....but the number of people coming up to me while traveling telling me how they wish they never sold theirs .... lol
Will update with result of the combustion test early afternoon for (PST).
cheers!
2025
• New OME rear and front shocks at 250K
• New steering stabilizer at 250K
• New transfer case oil 75w90 at 250K
• New oil change and filter at 249K
• New engine air filter 249K
• New OEM Denso starter motor 249K
Major Suspension & Drivetrain Overhaul
• September 2025: Additional front end work
• Front lower bushings replaced
• Iron Man caster plate kit installed
• Front drive shaft replaced again
• 2025 (245K miles): Charcoal canister replaced
• 2025 (241K miles): New front brake pads installed – 100 series pads (larger surface area)
• 2025: New front drive shaft
• 2025: New Iron Man caster bushings and plates
• 2025: New drop-down sway bar links
• 2025: All new rear bushings
• 2025: Two new BF Goodrich All-Terrain KO3 tires installed on front
• 2024: General maintenance and continued use
2022–2023 – Drivetrain Upgrades
• August 28, 2023: Replaced fusible links to address battery drain issue
• August 21, 2023: Fixed swinging mirror issue using 3D printed part
• 2023: Slee rear swing-out tire carrier bearings serviced
• 2023: 2 ×
Renogy Smart Lithium Iron Phosphate 12V 100Ah batteries installed
• 2023:
Renogy 2000W inverter installed
• March 2023: Alternator replacement – emergency repair - aftermarket currently installed.
• February 2023: Installed new driveshaft to eliminate driveline growl
• Summer 2022: Professionally regeared to 4.88 ratio (234,035 miles)
• April 6, 2022: 2 New BF Goodrich KO2 tires (233,604 miles)
• April 4, 2022: New front and rear brake pads installed (232K miles)
2020 – Expedition Equipment
• August 9, 2020: Mounted water pump for Camplux propane water heater
• August 9, 2020: Installed quick connect for solar panel wiring
• August 9, 2020: Installed 2 key switches for fridge and water pump control
• August 9, 2020: Mounted Slee rear basket
2019 – Further Upgrades
• October 24, 2019: New hoses to and from charcoal canister installed (223K miles)
• October 24, 2019: New front brake pads installed
• October 24, 2019: New wiper motor installed
• 2019: New driver side door seal installed
• 2019: New battery terminal connectors installed to clean up wiring
2018 – Second Major Rebuild
• December 16, 2018: Front end components replaced
• New headlight assemblies
• Front grille
• Front valence
• December 16, 2018: New Hella horns installed
• 2018: Rear differential serviced
• 2018: ScanGauge installed
• 2018: New driver seat foam installed
• 2018: New leather seats installed from Land Cruiser Heaven
• October 19, 2018: Second Engine Rebuild (217,184 miles) after suspected rod knock
• Complete engine assembly removal and replacement
• R&R engine assembly including fuel and electrical transfer
• Engine oil service and inspection
• Steering knuckle rebuild – both sides
• Replaced all seals and gaskets
• Steering box replaced
Engine / Ignition / Cooling Components Replaced:
• Water pump
• Thermostat
• Thermostat gasket
• Distributor cap
• Distributor
• Ignition wire set
• Spark plugs (set of 6)
Brake / Steering / Front End Work:
• Front brakes and rotors
• Steering knuckle service (both sides)
• Steering box replacement
• June 16, 2018: Warn winch self-installed
2017 – Electrical System & Repairs
• 2017: Viper alarm system with remote start installed
• Includes 2 key fobs with remote start capability
• System has ability to upgrade to GPS tagging
• 2017: Idler pulley replaced self-installed
• 2017: Power steering pump replaced
2016 – Drivetrain & Protection Upgrades
• 2016: Isotherm Cruise 36 marine refrigerator installed
• 2016: Bumper & Protection upgrades
• TJM T17 Front Bumper
• Slee 80 Series Rear Bumper with dual spindles
• Tire Carrier and Ladder
• 2016: Tailgate storage installed with marine hatches
• 2016: Dometic CDF11 fridge/freezer installed in center console
• 2016: Complete audio system upgrade
• New front and rear speakers
• Rearview camera installation
• 2016: All power steering hoses replaced
• 2016: New charcoal canister installed
• 2016: New liftgate struts installed
• 2016: Fire extinguisher mount installed
• 2016: Fuel filter replacement self-installed
• 2016: Starter rebuild kit self-installed
• 2016: Knock sensor replacement after wire separation
• 2016: New fan clutch installed
2015 – Major Systems Overhaul and head gasket job.
• August 2015: White Knuckle Rock Sliders installed
• July 2015: Upgraded to 35” BF Goodrich All-Terrain KO2 RWL tires
• June 2015: ARB rear locker installed with compressor mounting and electrical hookup
• 2015: New tie rods and drag links from Slee
• 2015: New tie rods and ends installed
• 2015: Front suspension bushings replaced
• 2015: Left and right front caliper replacements with extended soft brake lines
• 2015: New belts and fan clutch installed
• 2015: Magnaflow catalytic converter installed
• April 2015: First engine rebuild at YotaMasters in Corona
• Due to head gasket failure, complete valve job and cylinder head work
• (176,390 miles)
• March/April 2015: Deflaring completed and stock roof rack removed
• January/February 2015: New heater components and valve (was completely corroded)
• January/February 2015: New radiator installed
2014 – Initial Purchase & First Upgrades
• 2014: Entire cooling system overhauled with new lines
• November 2014: PHH replacement after failure during trip to Mammoth Lakes
• August 2014: ARB high output 12-volt compressor
• August 2014: ARB Air Locker for Toyota LC 12-bolt
• August 2014: Premium suspension system installed
• OME 80 Series long travel sport springs and castor kit
• OME coils front and rear with +20mm height
• Long Travel Sport shocks
• Front caster correction kit
• July 2014: Purchased with 173,205 miles
