Rough Idle and Poor Gas Mileage
Tahlequah, OK
Hey All I have gotten many of the bugs worked out of my 1994 Cruiser but I am still having an issue with a slight miss at Idle, and Poor Mileage. It is idling a little high at about 1100 rpm. I am getting 10 miles per gallon every tank since I have had it running. It has New Rotor, Cap, Spark Plugs, seals, and wires. Most of the Emissions system replaced and cleaned. TB Cleaned. I Have not rebuilt the injectors yet. Where do I start? thanks.
10 sounds normal.
I'm at 9.7 mpg
The more armor I add the lower it gets
Is it throwing any codes? Otherwise there's a million places those symptoms could start. For instance, mine was high idling (1500+) in park and neutral and turned out to be cooling sensor and sender unit. Could be as simple as a bad vacuum line. Although my O2's are also basically fried....sigh i have to sort out my exhaust soon.
multiple things could be attributed to that,do you still have EGR and PAIR?your high idle does sound like a vacuum leak as stated above.check your throttle cable as well if you removed the throttle body to clean it.
i was getting 10mpg city before i removed my pair and EGR,now its 10.5 to 11 city,stock gears 305/70-16 tires.
