rough country leveling kit, will it fit?
Arkansas
Looking at getting front end done next week, control arms, tie rod ends, figure I might as well do struts at the same time. Everything I've read said fj cruiser, 4runner,tacoma struts all fit, but rough country doesn't list anything for lexus. Anyone verify these will work?
Thanks Tom
Anything listed for 03-09 4runner will fit but the different weight would make it sit lower.
5th gen are closer in weight to stock GX470. The front lower front bushing are a bit wider but easily make fit. You could use two nut and long bolt to spread the lower mount apart or grind the lower bushing a bit.
The M1 monotube that are supposed to be similar to Bilstein 5100. They also have lower end N2 which is twin tube low pressure gas.
Thanks for the information, I wonder if the v8 4runner coilovers would be similar to the gx470 as far as spring rate?
Tom
