roll cage help?
Where Metal Tech uses DOM in their "A" Pillar, and HREW for the Rest.
Not True. They used to use HREW for some parts of their cages however now the entire cage is 2" DOM. They also have had all their DOM custom made to their own specs regarding elasticity etc. which are higher even than the "DOM" specs.
Maybe you should let Metal Tech Post up, Id love to know the truth from them, but from what ive heard they are only DOM on those A Pillars. Their website is not clear on the material used.
Regardless the difference between DOM and HREW is minimal, Google it and Read all you want,
We can build any of our cages of DOM if the customer would like, on our FJ-40 kit it would add $150 to the price. we can build it out of Chromoly if you want :D. Our cage kits come with quite a bit more tube than the MT Kit, we include a dash Spreader, Overhead spreaders, and have options for door Bars and Gussets to your Liking.
x2
you just created a weak point in your cage, kinda like a crumple zone in the front ends of cars.
Agreed, Bends are Not as Strong as Straight Tube,
We can Not bend that tube for anyone who wants it straight, its such a minimal bend that it can ship either way and the spreaders will work the same!
If that 5* bend is bothersome to you, What would you say about the MT Design?
Either Way NONE of us are Structural Engineers, and both designs should save your ass if needed. Everyone and their brother has a MT cage and they stand by them. i know our cages are well built, Look good, and will set your cruiser apart from the rest of the 40's..
We don't want to end up like the 80 series guys and all have matching rigs on the trail ;)
I'm not trying to cause any problems, but people have a tendancy to put misinformation on the web that becomes gosple. I have spoke w/ Mark recently and very indepth about his cages. Yes, they used to be DOM A pillars and HREW everywhere else however his new cages are all DOM that is made specificly for them.
Both cages are Great Products and like Isotel said either would save your ass if you need it.
No harn no foul.
DOM -HREW -- What's in a name?
DOM, ERW, HREW...all types of "mechanical tubing", as opposed to pipe. All mechanical tubing is dimensioned by OD and a wall thickness.
DOM is actually not a type of tubing, but a process that is applied to tubing after it is initially constructed. It is Drawn Over a Mandrel...which "cold works" it, giving more exact dimensions, smoother finich, and better allignment of the crystal latice structure. It is NOt seamless tubing, and it started life as some sort of EW (electric welded) tubing. Most commonly, when people say "DOM" they mean 1020 mild carbon steel rolled electric welded tubing that is then drawn over a mandrel.
Other mechanical tubing that is not necessarily drawn over a mandrel can be either hot or cold rolled (i.e. rolled from a flat strip into a tube when either hot or cold) and most commonly available will then be electric resistance welded (ERW) to form the final tube.
Generally...cold forming and cold working add strength and uniformity to a product, and reduce stress.
So VERY BASICALLY, in terms of strength you usually have, in order:
DOM
CREW (Cold Rolled Electric Welded)
HREW (Hot Rolled Electric Welded)
Again...these are all just processes, to fully call out the material, you need to specify the type of steel...but most commonly we are talking about 1020 mild carbon steel.
1020 is normally used in the manufacturing of small-diameter or thin-wall DOM steel tube. DOM is formed from strip and electric-resistance welded, then cold drawn to size. The cold drawing process causes the weld line to virtually disappear.
Typical Mechanical Properties: Tensile strength (ksi) 80
1018 is normally used in the manufacturing of cold drawn and hot finished seamless tube. The production of seamless tube is generally made by piercing a hot rolled bar. Hot finished is generally furnished in the unannealed condition, whereas cold drawn seamless is supplied in the unannealed or S/R annealed conditions, depending on the size.
Tensile strength (ksi) 60
1010 is normally used in the manufacturing of electric-resistance welded tube. The product is available normally in cold rolled strip (16 gauge and lighter), and hot rolled strip (.083" wall and heavier). The product can be obtained in the as-welded condition (flash-in) or in the flash-controlled condition.
Typical Mechanical Properties: Tensile strength (ksi) 45
1026 grade is normally used in the manufacturing of DOM, cold drawn seamless and hot finished seamless. This grade normally furnished over 2" OD, with walls heavier than .156". A variety of thermal treatments can be supplied, depending on the type and size of material.
Tensile strength (ksi) 87
Contnuous (butt welded) pipe process.
The continuous process produces a full range of pipe sizes from only a few different widths of skelp. The coils of skelp, or strip, are fed into the mill and their ends welded together to provide a continuous flow. The strip passes through a pre-heater and into a furnace. The heated strip is shaped into an arc of about 270° in a forming stand before passing into the welding stand. There a nozzle applies oxygen to the edges to further heat them as they are pressed and welded together. The pipe's OD and wall thickness are reduced in a stretch-reducing mill. Pipe is then cut to length, reduced to the required size in a sizing mill and water-cooled before being straightened. It is then ready for finishing
Typical Electric Resistance Welded tube process
Steel strip is unwound from coils and side-trimmed to control width and condition the edges for welding. The strip then passes through a series of contoured rolls which progressively cold-form it into a circular shape. The edges are forced together under pressure and welded by heating the steel to temperatures between 2200° F and 2600° F using copper contacts or coil induction. Weld flash is removed from the the inside and outside surfaces of the newly-formed pipe, and the weld zone is heat treated to ensure homogeneity between the base metal and weld. The weld is subjected to in-line nondestructive testing, and the tube then passes through a series of sizing rolls to attain its precise finished diameter. It is then straightened and cut to the desired finished length.
DOM tube being constructed, starting as ERW and then being drawn over a mandrel.
The manufacturing process for DOM tubing begins with coils of steel, which are slit to the proper width for the desired tube size. The strip is cold formed and passed through an electric resistance welder which joins the edges together, under pressure, to complete the tubular shape. After testing the weld's integrity, the tubing is cut to length for further processing
Seamless tube construction
The production process for seamless tube begins by heating a steel billet to about 2250° F. The red-hot billet is rotated and drawn by rolls over a piercing rod, or mandrel. The action of the rolls causes the metal to flow over and about the mandrel to create a hollow tube shell. After reheating, the shell is moved forward over a support bar and is hot-rolled in several reducing/sizing stands to the desired wall thickness and diameter. The tube, which has grown significantly in length during the piercing and sizing processes, is then cut into sections and conveyed across a cooling bed to cool slowly in the air. It then receives whatever finishing processes are needed to meet customer requirements.
Steel tubing is usually supplied in one of the following forms:
Seamless Tube.
This is expensive and specialized stuff. It IS NOT the commonly used (and misreferenced) DOM tubing, as DOM tubing does indeed have a seam (albeit, almost invisible - more details below). True seamless tubing is uncommon in 4x4 and automotive use. It is seamless because it is manufactured by a process know as "extrusion" where a solid bar of steel is pierced down the center with a die, at unthinkable pressures, to form a tube. The process looks similar to how hollow pasta (macaroni etc) is made. There are 2 sub-types of seamless tube:
Cold Drawn Seamless (CDS) Tube is normally drawn to O.D. and I.D. dimensions and produced to standard dimensional tolerances (this differs from most other types of tubing except DOM) . It is normally made from SAE 1018 and is considered good quality.
Hot Finished Seamless (HFS) Tube is lower in cost than cold drawn and most applicable where precise dimensions and surface quality are of secondary importance. It is manufactured to O.D. and wall dimensions from SAE 1026 steel and is scaly, less dependable and not as strong as cold drawn tube.
Electric Resistance Welded (ERW) Tube
ERW is the most economical and readily available type of mechanical tuning. It is produced by taking a flat bar of steel and rolling it into a tube shape (picture rolling up a newspaper - but without any overlap) and then welding the seam - by, you guessed it - electric resistance - hence the name. Electric resistance welding is somewhat like a long, continuous spot weld. It's often computer controlled and extremely consistent. ERW is normally SAE 1010 (for wall thickness < 16 ga) or SAE 1020. ERW tube comes in 2 flavours:
Hot Rolled ERW (HREW)
HREW is rolled into a tube at elevated temperatures, usually way above room temperature. This produces a tubing that is more malleable and therefore easier to form but that is also not as strong, is supplied covered with scale, and not as uniform in dimension as cold rolled. It is also quite a bit cheaper than cold rolled.
Cold Rolled ERW (CREW)
CREW is manufactured by a process in which a steel bar is rolled into a tube and the seam welded, usually at room temperature. Compared to hot rolled, CREW is stronger - (greater yield strength) - because of the improvement in the crystal lattice structure from improved grain size, shape, and orientation imparted by being worked at cold (room) temperatures), straighter, has a much smoother and more uniform surface finish, and is made to much tighter, more consistent dimensions. It is the best economical choice for tube work, and because of the better surface finish and tighter dimensional tolerances it is much nicer to work with than HREW.
Drawn Over Mandrel (DOM)
Strong and well-finished DOM is an electric resistance welded tube tested for soundness of weld and drawn through a die and over a mandrel. This process imparts significantly improved mechanical properties to the tube, due to the cold working process. It is considered a high quality tube, and is normally constructed from SAE 1020 or 1026 steel. Note that, technically DOM refers to the process by which the tube is finished after having started as an ERW tube. Technically, DOM is not a type of steel tube, but rather a process. As so often happen though - in common use the term has become accepted to mean a specific type of tubing rather than a process. In this case, when people say "DOM" they normally mean an ERW tube drawn over a mandrel at (close to) room temperature and made from SAE 1020 steel. It is normally drawn to O.D. and I.D. dimensions. Here is what the Steel Tube Institute of North America has to say about DOM:
The DOM Manufacturing Process
The manufacturing process for DOM tubing begins with coils of steel, which are slit to the proper width for the desired tube size. The strip is cold formed and passed through an electric resistance welder which joins the edges together, under pressure, to complete the tubular shape. After testing the weld's integrity, the tubing is cut to length for further processing.
The cold-drawing process creates a uniform, precision product with substantially improved tolerances, surface finish and tensile strength, increased hardness and good machinability. In this process, the tube is cleaned and annealed, and one end of each length is squeezed to a point so it can be gripped by the drawing mechanism. The tube is then drawn through one or more dies and over mandrels. This reduces the diameter of the tube and thins its walls to the required dimensions in a controlled fashion to provide the qualities desired in the finished product. Metallurgically, drawing improves the tube's concentricity, tensile strength, hardness and machinability. Close dimensional accuracy is achieved through tight control of both outside and inside diameters.
Whew, after all of that remember this. If you are getting 1020 DOM, life is good, and that hot deal is probably hot.
