Rocker Panel
Discussion in 'FJ45 Owners Club' started by krzyabncanuck, Jul 4, 2005.
  1. krzyabncanuck
    krzyabncanuck USFS HOTSHOT GOLD Star
    8,717
    735
    Apr 5, 2005
    NC
    Over the next year or so I am going to be needing some serious help here, I am attempting to put a 64 45lwb back to good running condition, mostly body work.
    One question for right now is , the drivers rocker panel is pretty much totally shot, serious bondo in it right now, can i get a replacment panel or just cut out bad and weld in new.
    Again thanks much in advance for all the help i will be asking the experts for.
    PS, I suck really bad right now at body work, but looks like i will be getting some practice here.
  2. 65swb45
    65swb45 Elder Statesman Supporting Vendor
    24,352
    9,362
    Apr 14, 2004
    818-953-9230
    I can't think of a better place to start when it comes to welding in new metal, as the rocker has a minimal amount of bends or attachment points. There should be a lip coming down from the tub that overlaps from the inside. As long as your metal is solid from that point up, I would cut and weld in with a mind towards using that as a strenghening seam for the old and new rocker sheet. I hope I said that clearly.
  3. krzyabncanuck
    8,717
    735
    Apr 5, 2005
    NC
    Thanks mark, thought it would be pretty easy to do and if i do mess it up then i can always get one from CCOT and have someone else fix it , but i am going to try it myself first.
  4. 65swb45
    24,352
    9,362
    Apr 14, 2004
    818-953-9230
    You'll do fine. Remember to take pics......after you grind all the booger welds off! ;p
  5. krzyabncanuck
    8,717
    735
    Apr 5, 2005
    NC
    I take it you have seen some of my welding before then. :) :)
