Road-going air pressure on BFG A/Ts?
Austin, Texas
Since most of my driving is in-city with my 31x10.5 BFG A/T tires, I'd like to maximize my MGP rating as much as possible. What's the conventional wisdom on how much to inflate these things?
I've been running mine around 30-35 PSI around town and highway. I think the max cold pressure is 40 on those tires and I'll bump up to that if I'm carrying around a particularly heavy load of stuff and/or people.
I get around a combined city/highway of 12 MPG with all the stuff I normally carry and my driving habits. I've tried lower PSI for comfort and higher for load capacity and neither really made any appreciable difference to my MPG so I just compromised with the 30-35 range.
The ideal pressure will depend on the weight of the rig and the width of the wheels. Ideally you want even wear across the entire tread area. try chalking a heavy mark across the tread and drive around for a day and see where is is rubbed off. If the edges are gone, you need more pressure. If the center is gone but not the edges, you need less.
Double check your max cold pressure...I believe mine state 65 psi. That being said, I have found that running my 30's on stock wheels @ 44 psi cold seems to render the best road manners.
following is how I run my 33x10.5 BFG AT, which is how I ran my 33x9.5 BFG MTs IMHO all of it would apply to the 31" version too, maybe with a little less crowning effect
No less than 36-38psi if I'm road only. Even on good dirt roads, if running all day I air down to 30 or less, which makes a nicer ride, down to 20ish if rough and wash boarded and tougher routes are in the plans.
You might see some "crowning" at high psi, I rotate at every oil change, (4K miles or once a year which ever comes first) And lower the pressure to 32 sometimes to help counter the crowning effect on the wear pattern, Usually I do this when I am airing back up from a desert run, stop at 32 for a couple hundred miles then air it on up to 38ish for around town. My rig is pretty much a garage ornament, so this whole cycle of air-up-then-down may only happen 4 times a year...seldom put 3K a year on it.
And it looks it!
