Looks good. That bumper work they do it nice.Just waiting on my gas can. Need to put in my 5” lights.
Nice set up. Word of caution. I lost a jerry can bombing through the desert because the bungee cord holding the jerry can snapped. Think of that and try to find a better solution to hold it in place. I was lucky and @steenh was not far behind me and picked up the can for me. I now use a harbor freight ratchet strap. Hasn't failed me.....yet. And the rat het strap came in handy on a windrock trip when i tore a passenger side rear LCA off. Used the strap to hold the axle in place until i located a local fab guy to fixed me up a temporary LCA. Pic of that ....Just waiting on my gas can. Need to put in my 5” lights.
Please show when installed. Looks goodMy bumper came in. What an amazing piece of work. Instead of powder coating / bedliner route, I decided to make things even more difficult for myself and chose to coat with steel-it. Surface prep requires scarification of the steel so that the stainless steel particles can fill the voids. After sanding, I cleaned all the surfaces with simple green aircraft & precision cleaner, then wiped all surfaces with isopropyl alcohol. Steel-it sprays quite well, and I expect to get a few coatings out of the amount of cans I have. Can't wait to see how this will turn out once the coating dries!
Nice post up pics when you are done. Other than mine this is the only other dual swing I've seen. The 3 jerry basket comes in very handy, and for me also does the job of a ladder for roof rack gamesMy bumper came in. What an amazing piece of work. Instead of powder coating / bedliner route, I decided to make things even more difficult for myself and chose to coat with steel-it. Surface prep requires scarification of the steel so that the stainless steel particles can fill the voids. After sanding, I cleaned all the surfaces with simple green aircraft & precision cleaner, then wiped all surfaces with isopropyl alcohol. Steel-it sprays quite well, and I expect to get a few coatings out of the amount of cans I have. Can't wait to see how this will turn out once the coating dries!
Yep, yours was the reason I wanted one! I just have to figure out where the hell everything goes. It's difficult to sift through this thread to get clear and concise instructions as to where each bracket goes.Nice post up pics when you are done. Other than mine this is the only other dual swing I've seen. The 3 jerry basket comes in very handy, and for me also does the job of a ladder for roof rack games
Yeah I did mine and also another local buddy’s install. It’s a solid full day install, even the 2nd time around. but 2 years later I’ve had no issues and am happy with it. it’s solid has taken a ton of hard hits and never budged. I LOVE having 3 Jerry cans, those take up a boatload of room anywhere else. FYI there is a guy on mud that brings all the Scepter cans back from Canada, I order everything from him.Yep, yours was the reason I wanted one! I just have to figure out where the hell everything goes. It's difficult to sift through this thread to get clear and concise instructions as to where each bracket goes.
Thank you, I appreciate all the help you've given me so far.Yeah I did mine and also another local buddy’s install. It’s a solid full day install, even the 2nd time around. but 2 years later I’ve had no issues and am happy with it. it’s solid has taken a ton of hard hits and never budged. I LOVE having 3 Jerry cans, those take up a boatload of room anywhere else. FYI there is a guy on mud that brings all the Scepter cans back from Canada, I order everything from him.
I think the main discussion about the install is whether the wing brackets have the flat plate facing up or down. People have done it both ways, I think it really depends on which holes line up with the frame holes on your truck. Feel free to PM me for any specifics, it’s been a little while but I remember most of the parts that were confusing at the time. Once you have all that plastic off the brackets make sense more
side note, what lighting do you have on your front bullbar? I'm looking into adding someThank you, I appreciate all the help you've given me so far.
I have some Amazon cubes on top of stedi type x pros all wired into a bantam x. I also have yellow covers I can clip onto the stedis when it's foggy outside. Not bad for the price, and the build quality on the stedis are really nice!side note, what lighting do you have on your front bullbar? I'm looking into adding some
Love the look of LC. What year. I have a 2008 the same color and happy to see what everything looks like on yours. Great jobThe quotes I got around here were insanely high ($400-500) so I coated the bumper in raptor liner. It was a process to get it done, but it looks great and the finish is very scratch resistant. I saved about $200 doing it myself.
Nice looks good. Where did you order the Stedi’s from? I don’t see any vendors outside of AustraliaI have some Amazon cubes on top of stedi type x pros all wired into a bantam x. I also have yellow covers I can clip onto the stedis when it's foggy outside. Not bad for the price, and the build quality on the stedis are really nice!
From Australia. They ship DHL and process orders immediately. I've gotten items from them in under 5 days in the northeast US!!Nice looks good. Where did you order the Stedi’s from? I don’t see any vendors outside of Australia
Thanks for the info. Looks like a quality alternative to the $ARB option. I might have to push those up on my want listFrom Australia. They ship DHL and process orders immediately. I've gotten items from them in under 5 days in the northeast US!!
I've been using these as standoffs for the license plate adapter. If they are the same spacing as the wing to frame mounts you could use them there. I used carriage bolts for that, but getting a wrench on the nuts was a pain.
