Right Rear Speed Sensor Damaged / Part Number Check (1 Viewer)
DFXR
Oakland, CA
2000 US-spec LC, no AHC
I managed to tweak the right rear ABS speed sensor harness while wrestling with the infamous top nut of the right rear shock. It's the harness section that runs from the shock mount down to the caliper, and I damaged it right at the terminal on top of the shock mount.
I now get an intermittent ABS/VSC warning on the dash, no codes. It will go away when I wiggle the terminal back there or even slam the rear hatch. No brake or driving issues other than the lights.
You can see the damage to the black wire in the photo below. It probably took a beating in every shock replacement since new.
Anyway... before I try to remove, repair, and potentially make matters worse, I want to confirm the replacement part number. Can someone more knowledgeable than me chime in?
If I replace the whole section of harness, is it as simple as plug and play or will I need to reset the ABS? Any VSC-related issue I should be worried about in the short term with the damage there?
Thanks in advance.
Here's the terminal location:
Here's the part number I am looking at: 89545-60030 Sensor, Speed Rear RH
