Replacing radio cassette in 1998 75 series
Australia
I've trawled the Internet and I think I've found the wiring diagram I need to replace the stock Toyota (Fujitsu Ten) radio cassette with something a bit more modern with Bluetooth etc.
This diagram matches what I have except there is a wire connected to pin 5 on the small plug but I only have a + cable for illumi on the new radio. Either I don't need it or the diagram is incorrect?
Wiring colours as follows, Large plug first...
1. Light Green (FR +)
2. Pink (FL +)
3. Grey (ACC, ignition)
4. Red (+Battery)
5. Blue (FR -)
6. Purple (FL -)
7. Brown (Ground)
8. Empty (power antenna)
9. Empty (power AMP)
10. Green (Illumi +) Dash dimmer
Small Plug
1. Red (RR +)
2. Black (RL +)
3. White (RR -)
4. Empty
5. Brown (Illumi -) ?????
6. Yellow (RL -)
Any help confirmation welcome, thanks.
Are you talking about this jewel or something slightly more modern? :D
dude, pay the $5 and get the adapter ... plug and play.
fawkin with the wiring is a total waste of time and energy and brain cells ... at our age we need to keep as many as possible.
Wow! Yours is older than mine! ;)
Here's what mine looks like.
the adapter is color coded and plugs right into the original harness
you wire the adapter to the deck and plug and play, easy peasy, 1 banana operation.
You will see my radio displayed in a Toyota Museum some day. It will probably have it's on security detail due to the high value. :D
What adapter? Is the adapter specific to the new unit? My new one is a Sony, how does the adapter know which configuration you have, there seem to be many variations.
http://www.tehnomagazin.com/Auto-radio-car-connector/TOYOTA-Car-Radio-Wiring-Connector.htm
I got one for my 75 series from Strathfield Car Radio in Perth. Super Crap should have them.You buy one piece of wire and plug for a Sony and you buy another for the Landcruiser.Total cost around $20 from memory.
You join it all together and sit down and have a beer.
Dont go cutting anything ,its the caveman way.
I did a bit of both in the end as there were some minor differences, here's the Frankenstein's monster I finished up with :)
Because there was no pin in the connector that goes into the new radio for the dashboard light dimmer. I couldn't see how to move the pins and thought I'd break it so i transplanted the connector and wires provided with the new radio and attached it to the adapter. Yeah I know I could have done some of this without the adapters but this is much tidier and it did save me time.
