I'm more than half-way in to this project after about 4 hours of work. It certainly isn't for the timid. CDan was kind enough to hook me up with new parts (thanks!). I have the right side manifold off with not too much trouble. The left (driver's) side is looking damn near impossible.
Can someone with a service manual give me advice on:
1. What is the torque on the manifold studs. 7 out of 8 studs came out of the head vs. the nut coming off the stud. So, I have to separte the nut from the stud and re-insert the studs in the head. They came out clean and the studs have a Torx fitting on the end to allow installation. I just don't want to torque them too much!
2. Required torque on the exhaust manifold nuts.
3. How in the %&*/#$^%@#$ does the steering flex-shaft come off? Is it even possible to remove this with the steering gear still in the car? I can pry it back about 1/2" with a long steel bar, but it isn't enough clearance to even allow the shield to be removed. I'm afraid the manifold will be a similar story. I have the shield bolts out and the top four manifold studs out and had to quit. Bleeding too much from all my wounds.
I'll post some pictures and type a few pointers if I'm actually able to pull this off.
Oh, and the passenger side manifold that I pulled off looks fine to me. I can't see black marks that would indicate where it was leaking. Maybe just the gasket was leaking or the flange is warped? Either way, the new parts should solve that. I was just expecting to see something obvious for all that noise it was making!
Last, how clean does the mating surface at the head have to be? There is quite a bit of crusty oxidized aluminum (?) caked up around the exhaust ports. I cleaned most of it with a brass brush but it will take hours to get it all nice and polished. Ugh.
Mark
Mark
