Hi All, newby here trying to help my teenage son. He has an 1985 Bundera which has had an engine change. Now has 3L diesel from a late 90's Hilux we think. I suspect the trans is original, possibly a G52 not sure. We put a clutch kit in it that suited the 3L engine. Looked the same dimensions as the one that come out. Now I don't get any drive through the transmission. The gears all select. The pivot fork has free play. Clutch is pretty soft, actuates the pivot fork ok. When clutch is released I can hear quiet whirring, normal I think. It is up on axle stands. The handbrake is off. I'm thinking the friction disk has the wrong size spline, too big, but my research tells me that it should be correct. What am I not understanding? Just looking for a sanity check before I pull it apart again. Thanks, Adrian.
the clutch disc was installed inverted, the flat face was not facing the flywheel
