Replaced ABS Sensors Only to Throw More Codes! Help needed
Seattle, Wa
Pulled codes the other day for bad ABS sensors so I replaced them all. Now I’m throwing a right rear ABS sensor, steering angle sensor and ABS module.
Has this happened to anyone?
I’ve searched and searched and it seems like every situation is slightly different.
Battery install completed and no change.
I will change the right rear sensor and go from there.
I bled the rear brakes using the self bleed. Does anyone know if that still works if the module goes bad?
Does anyone know the part number for the harness that the right rear wheel abs/speed sensor is connected to?
