Replace Sway Bar Bushings?
Atlanta, GA
Both sides look like this:
Looks like they need replacing? Are there any other bushings I should replace while I am down there?
125,000 miles on 305/55 (33.2”) for the last 10,000 miles.
It’s time. Check your frame side ‘D’ bushings and the rear links too. We are seeing more and more 200/570’s in need of sway bushings as miles get up there. We stock this all @ Cruiser Outfitters and can put a kit together for you like we do for all the older platforms.
Example of our 100/470 kits:
Nice, does your 200 kit include rear end links too?
Crusty even before i lifted. Sub 60k miles…
We stock if all so we can assemble a front only kit or a front/rear as we have on CruiserTeq.com for all the 80/450-100/470 setups. Ping our parts team for more info: info@cruiseroutfitters.com
Do you notice any ride quality difference? Or just visually saw them. Wondering if my 13 is in need also.
Most common symptom we see (hear) from blown out sway and suspension bushings is squeaks.
I thought I was hearing some creaking/groaning/clicking noise occasionally when coming to a stop in certain situations that I had not heard before, but I could be crazy.
Some additional info for those interested in the Cruiser Outfitters kit. I emailed Cruiser Teq about this, because the bushings on my 08 are worn and cracking. Here is the parts list for the full sway bar refresh kit:
I was told to call the shop to order. Probably going to be my next purchase for the LC
