Has anyone replaced an oil pump on a 100 series while it was still in the truck?
I've checked the FSM and step one says "remove the engine". I don't want to remove the engine if I don't have to.
Here's the background: I'm replacing the steering rack and in the process of removing the oil cooler/filter assembly a bolt broke (the one that is closest to the front and exposed to the environment) and remained in the oil pump housing. I drilled it out and f***ed up the hole.
I will try to enlarge the hole and install a threaded insert, but just in case that fails I want to know what I'm in for.
Thanks for your time.
