Hey all, have a friend's 97 FZJ80 that he wants fixed. Originally, truck died on the freeway, restarted and ran poorly, then shortly died again and would not restart. When I first looked at it, I cranked it and it sounded like a lack of compression on all cylinders, so I suspected valve timing was off, ie timing chain skipped. Had it flatbedded to my house, where I charged up the battery and tried to crank it again. Now the starter grinds. It will sometimes catch, but engine does not spin. Starter cable gets very hot. Will also not spin with a breaker bar on the harmonic balancer bolt, so something is jammed or seized inside. Miraculously, it's stopped at about 2deg BTDC.
Pulled the valve cover, cam timing is spot on as far as I can tell by the dots on the gears. Little dirty under the VC, but cams don't look scored or have other unexpected wear. Did a leakdown test on a cylinder that has valves closed. Result was around 30 out of 100 PSI, spark plugs are pretty caked with burnt oil, and my friend confirmed that he has to add oil every couple weeks. Odometer is showing 350k+, so I think it's fair to say this motor has seen better days. Rather than wasting more time trying to get this engine to run on borrowed time, I suggested it may be better to just yank the whole thing and start fresh. Friend agrees it's probably time for a new motor, local machine shop says they've done a few of these and shouldn't have a problem. That's all fine and dandy, but now I'm wondering, how will I get the torque converter bolts out if the motor doesn't turn? Can I pull the torque converter out with the whole engine/flexplate?
Thanks!
Thanks!
They both start with "M".......
