Removing Intake Manifold
Trying to stack dimes
OK, so I'm just starting my Magnuson S/C install and I'm struggling with the wiring harness at the rear of the intake manifold. Do folks remove the bolts holding the harness to the manifold or undo the clips? If the clips, how to they come apart?
Bolt - those clips are the spawn of Satan
Thanks! And agreed on the spawn of Satan. I'll just keep wrestling with them.
Bolts are pretty easy with a 10mm ratchet wrench.
Clips are honestly very easy as well. There is an unlock tab and then they slide off the mount.
It's pretty easy when you can visualize the release tabs on the harness holders.
@Moby see this
Thanks all! I won - combination of bolts for one and tabs for the other two. And the supercharger install is moving forward again (slow build - father/son project).
