It all started with my quest to cure vibrations realized at highway speeds. I first removed my rear driveshaft and took it to have new OEM u joints installed. I also had it re-sleeved and balanced since it suffered some rock rash. The final product cured 90% of the vibrations.
At first, I figured I could live with the remaining, minor vibrations that were clearly in the front end. But, my worries got the best of me as I wanted the car to be as safe as possible for when my wife and nine-month-old daughter are in tow. I began my troubleshooting journey by removing the front driveshaft and inspecting the u joints. It was clear (to me, anyway) that the front u joints had a fair amount of wear which could contribute to the remainder of the vibrations. Finally, I locked the center differential and went for a spin.
Hallelujah! Vibe free! "Consider yourself lucky," me said to me.
Not so fast... After logging 50 or so miles in RWD, I noticed a faint whine that increased in pitch as the vehicle picked up speed. It doesn't change with transmission activity, which makes me think axle or center differential.
Is it possible I damaged the transfer case when cranking so hard to loosen the drive shaft from the output shaft? After all, I did snap a two inch extension in half when loosening the screws.
Likewise, is it possible I damaged the front differential's pinion bearing when removing the bolts on the front of the drive shaft?
Lastly, could the whine just be a characteristic of driving a full-time four wheel drive vehicle with the front drive shaft missing? The front axle and front transfer case flanges are just freewheeling with no rotational force (I.e. - drive shaft) to contend with. The whine is quite minor, but it was NOT there before. It reminds me of my old '88 and '89 Range Rovers.
Some basic vehicle info:
- '94 with 150k miles
- front axle rebuild 30k miles ago, including new trunion bearings (original wheel bearings)
- 5k miles on amsoil front diff fluid
- It's been responsibly used for its intended purpose, but is well maintained.
- 2.5 OME medium
- Slee castor correction bushings
- OME steering stabilizer
- 1" spacers up front
- 295/75/16 BFG ATs with 4k miles
- Front end alignment done with new tires
I'll be dropping off the front drive shaft to have new OEM u joints installed tomorrow.
I appreciate any opinions offered!
- Matt -
- 2.5 OME medium
- Matt -
