Still having difficulties here. Right now I've got the alarm/starter hooked to IG2 and the engine will continue running when I remove the key (for reservation mode). But when I try to remote start, there are just clicks. I measure 12v at the starter output after one of these clicks, but the starter does not cycle. If I put the key in the ignition and turn it to "on" when the remote starter is cycling, the engine will start. So, I'm thinking that I still need to power IG1 to get the starter to be enabled. Or maybe it's the 12/24v switchover that isn't engaging. I'll have to wire a relay to engage the second IG wire so they remain isolated. I don't think I can simply connect the output wire from the remote starter to both IG1 and IG2.
Someone with a remote starter in an HDJ81, I'd appreciate if you could look to see how the 2 IG wires are hooked up.
Looking at the EWD, I see the following:
IG1 (black with yellow stripe):
- terminal #2 12/24v switchover timer
- glow indicator
- asdasd
IG2 (black with green stripe):
- fuel cut solenoid
- terminal #4 of preheater timer
