Make darn sure your two manifolds are the same depth at each bolt location. I had this problem years ago when going back to a stock carb, I couldnt get an idle and discovered the vac leak. Even after having the exhaust side machined to match the intake it wasn't exact. I wasn't off much (IIRC about 4-7 /100's of an inch), but I ended up buying new flat machine washers from Austin Bolt (saw you were local to me) and placed them in a vice one at a time and filed off half to the same depth as my difference for each location. Then I used a Sharpie to mark the other side of the washer where I filed it so I could see the correct orientation when assembling. I used a stock TEQ manifold dry and torqued to spec and have never had an issue since.
