Relay continues to click at startup and shutdown??
Discussion in 'Diesel Tech / 24 volts' started by celibaterifle, Apr 17, 2018 at 4:53 AM.
  1. celibaterifle
    celibaterifle
    14
    1
    Feb 14, 2009
    Hey crew
    1991 HDJ80R
    I’ve an issue with, what I believe is, a relay continuing to click after start up and at shut down. Engine is a 1HD-T and there is an old turbo timer fitted.
    On starting the old girl, not always, but a lot of the time there will be a clicking noise, that sounds like it is coming from behind the glove box (right hand drive Aussie car). This will occur for up to 30sec before disappearing.
    On shutdown, once ignition key is switched off (but engine still running due to turbo timer), many times the clicking sound returns until I shut off the turbo timer.
    Clicking noise isn’t apparent at any other times while driving, stationary, etc, just at start up/shutdown
    Any ideas out there as to which relays I should be looking at.
    Could also be a solenoid I suppose, such as fuel cut off?
    I haven’t looked at wiring diagrams yet.
    Could the turbo timer, which would be about as old as the bus, be a culprit?
    Thanks
    Jimmy
  2. torqueluvr
    torqueluvr
    279
    11
    Dec 14, 2010
    Port Coquitlam, BC
    This is a tough one. Do you have a make and model of the turbo timer to see if someone has experience with it?
    I would get behind the glovebox and try to narrow down (hear and feel) where the clicking is, and go from there. May need a helper with the startup/shutdown process. Hopefully its as easy as a faulty relay and you pull and replace and away you go.
    Good luck!
    celibaterifle likes this.
  3. celibaterifle
    celibaterifle
    14
    1
    Feb 14, 2009
    Timer is an old model BES, hopefully uploaded a pic of one.
    Would it be wired to a relay behind the dash? Hadn’t thought about that...
    Cheers
