Regear polls
Regear Polls
  • How many 80 series owners have regeared because of bigger tires?
    Votes: 0 0.0%
  • What brand, manuf..?
    Votes: 1 100.0%
  • What gear ratio?
    Votes: 0 0.0%
  • Any breakage or failure?
    Votes: 0 0.0%
  • Total voters
    1
cc93cruiser
CRUZAHEAD
Hayward, Ca.
What manufactuer Ring & pinion you using?
What Gear Ratio and tire size?
ok disregard the funny poll, :mad: :D ....................................Just answer ?'s please....
I think this poll has a low likelihood of success. Maybe e9999 should write a faq on polling technique -
:grinpimp:
the flammin has begun :mad: ...............Just answer the damn questions :flipoff2:
Hi Robert,
My 94 is still running stock gears with 35" MTR's, but I intend to have 4:88's installed, Precision Gears have been the long running favorite here. There's a post the other day about All Pro Offroad having a new front gear option that's made in Japan by an OEM gear cutter. It's about the same price as PG's which will run about $400 for gears only F & R. My truck is very driveable with current setup but I live in Dallas, flat, not many hills and I don't drive far for work. Regearing should help give back some of it's pep.
I sure would like to find someone around here that would teach me how to set u my own gears. I'm a machinist and have all the precision measuring tools allready, and quite a few mechanics tools.
Bryan
if you have all the tools, buy a FSM and just do it yourself, save you a lot of money......I already have the install kits and gears---4.88s....I just had a couple of questions regarding other 80 series owners and the path they took while regearing.....
I run 315 BFG M/T's and I regeared with Precision Gears 4.88's. Before I regeared I had to use my brakes when going down steep decents or risk nailing the guy in front of me. The other thing is you have to keep your foot off the skinny peddle around town---sort of feels like having a supercharger:) If I had to do it over I would do everything the same as far as gearing goes.
4.88 Precision Gear
315/70R17 BFG AT's w/ ~50% tread = speedo ~5 mph off, seems a little "overgeared"
37/13.5R17 Toyo M/T's ~95% tread = speedo dead on, drives like it should
Note, I'm turbo'd so that probably makes a difference.
Bryan E said:
Hi Robert,
Bryan
Bryan man...you already have the skill set as well as the digital dial indicators, etc. that you need to get this job done. Having the metrology background that you should have makes this an easy job....
The only 'tough' part is getting in there and getting out the 3rd member for the bench to work on.
Cheers.
-o-
285s with OEM gears, all is fine...
4.88's, Truxus M/T 35's, Precision. AWESOME, quiet, drives great, wheels great, speedo 10% off (don't mind). If I did it all over I wouldn't change a thing!
