Redarc RTH!!!
afgman786
Gainesville, VA
Flashing green with quick blue. Not same as green blue for calibration
Yea I think its from the rain and humidity.. on a 600mile trip loaded up and no trailer brakes
If it continues to act up and you need to reset the controller the easiest way I found to do it was to reset the whole car by disconnecting the negative wire from the battery. It is a bit of a pain because you need to restore a couple of setting in the car that are lost. What happened with mine (not sure of the cause) was that it was trying to calibrate and failing. That is what Redarc told me. They eventually had to send me a replacement.
Given that the RedArc pulls right from the battery, if you don't want to lose all the vehicle settings, you can always pull off the connector on the back of the RedArc, wait a few mins, and plug back in. Your module is likely behind the drivers kick panel. Should be easy day.
I'm almost at my destination. Had a few scary moments but glad the 200 brakes aren't old
Will definitely look into these things though. Thanks fellas!
