Nope.
You know, his 'Nope' could have been in response to your last sentence.
A stategically placed "recovery damper" would not hurt your winching efforts.
Nope.
I'm sorry, Spike. I don't follow.
I took his short reply as total disagreement of anything I said. But, no matter. We're just batting around opinions. Mark sounds like he's got some good experience. I just feel strongly about encouraging caution when winching. Mistakes in this area can be costly in $ and (human) body parts.
Granted, synthetic line breaking is more violent due to the stored energy.
I have had a few cables fail over the years. I have seen others have cable failures. I have yet to see one which was "violent". I have yet to speak to anyone who has first hand seen a cable that broke and did damage. (Make sure you are talking about a cable breaking and doing damage, and not a mounting point or other rigging components before you toss out a story to argue against my point.)
Mark...
YouTube - Dyneema rope VS steel rope - strength test - break test
Wire rope
YouTube - In House Break Test B -- Halo, LLC.
Both will recoil... But syn. line has less mass coming at you than steel.
that second vid though has a loop and a mass at the end of it.
A winch line with an eye and hook on the end, recoiling after the attachment point fails is a completely different thing than a cable failing and recoiling by itself from the break point.
From what I saw of that second vid, the piece that flew with the cable was not a significant mass. Would have been enough to increase the whack at close range, but it probably would not have added to the carrying force of the cable very much.
Mark...
If this were the only consideration when deciding between synthetic and steel it might make a difference. However I've been pretty much convinced that overall steel has the advantage over synthetic.Granted if the hook and recovery point follow the line, it's an entire different story. But there is less mass with a synthetic line whatever remains on the end compared to wire rope. So the effects of what happens when it reaches the point where it stops will be diminished.
There was no piece the flew with the cable. The point of the vid was to imagine all that wire rope coming at you compared to the 4 pounds of 100' synthetic rope coming at you. Both will recoil but syn rope will cause less damage.
I personally don't have a dog in the hunt. Use what you are comfortable with. But wire rope will come back at you with more force than syn rope. You can't beat physics.
