Recommendations: Mounting ROTOPAX 2G containers on ARB Base Rack.
7000ft
Flagstaff,AZ
They can both me made to work, including the ARB T Slot bracket. You may have to drill holes in your Rotopax Universal Plate.
There are a lot of different configs you can do, so you need to put your Universal Mount Plate on the roof and mock it up. Assuming Front/Rear, it can span 2 or 3 cross bars, so you have to choose which one to go with and the see.
I mocked mine up using the T-Slot, then re-purposed the T- Slot, so sorry no pix at this time.
I was going to order more T-Slots, but now I am now thinking of using the Bridge Plate as I did not know about that. I could use a single bridge plate and have it span 2 beams.
Thanks for your impute and suggestions . I'll tackle that project when I get back from the Overland Expo in CO.
I'll add to this thread when I figure it out.
Maybe you'll beat me to it!
Thanks again.
Bob
Looking at the various options, the T slot adapter would be my first choice, and the bridge plate adapter my secondl
I don't use rotopax anymore (got an oem sub tank for fuel, and the dometic 1/2 jerry system for water), but if you have a drill and some aluminum flat bar anything can be made to be rotopax compatible.
